The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I tried to import the URL to webframe widget. The problem is I cannot load the page. (It shows the website refused to connect.)
My website is host on pythonanywhere. I know the thingwrox webframe can only support https, so I configured https and https certicicate.
Does anyone know how to solve the issue like this?
Thank you!
Matt
I got the issue. My host setting for X-Frame-Options should be changed to "Allow-From".
Thanks for your help!
Matt
Can you please provide some more details,
1.Path of the page.
2.What is the URL mapped to Webframe widget?
Aruna
The URL is (hind it after sloved) I put the same URL in webframe widget.
Matt
Matt
Better solution: Add the following URL parameter "?rs:embed=true" (without quotes).
