Thwx 7.4: Failed to load FlxCore library
SOLVED
Re: Thwx 7.4: Failed to load FlxCore library
Sushant Pandey
I did try the solution in link you have posted. The application log is as below
2017-04-24 10:52:44.621-0500 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ====================================================================
2017-04-24 10:52:44.621-0500 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Failed to load FlxCore library. Ensure it's in PATH (Windows) or LD_LIBRARY_PATH(other platforms) or set with the VM arg, -Djava.library.path. Error message : com.flexnet.licensing.DllEntryPoint.entry([B)I
2017-04-24 10:52:44.623-0500 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ====================================================================
2017-04-24 10:52:44.623-0500 [L: WARN] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Shutting down the Platform.
Please let me know if I need to post any other portion of the log as well.
Thanks in advance
Update: I am working with Windows 10
Hi Rishit
Could you post the output of the following:
-open a command prompt on your Windows machine and execute set PATH
post the output here.
Also in the same command prompt could you navigate to <Tomcat>\webapps\Thingworx\WEB-INF\extensions folder and execute the command dir, and post the output here too .
Christophe
Below are the responses:
1) On executing the set PATH
\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files\nodejs\;C:\Program Files (x86)\Skype\Phone\;C:\Program Files\PostgreSQL\9.6\bin;C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx\WEB-INF\extensions;C:\Windows\System32\wbem;C:\Users\rishi\Anaconda3;C:\Users\rishi\Anaconda3\Scripts;C:\Users\rishi\Anaconda3\Library\bin;C:\Users\rishi\AppData\Local\Microsoft\WindowsApps;C:\Python27;C:\Python27\Scripts;C:\Program Files\Git\usr\bin;C:\Program Files\Heroku\bin;C:\Program Files (x86)\Microsoft VS Code\bin;C:\Users\rishi\AppData\Roaming\npm;C:\Users\rishi\AppData\Local\Google\Cloud SDK\google-cloud-sdk\bin;C:\Program Files\Docker Toolbox;C:\Program Files\PostgreSQL\9.6\bin;C:\Windows\System32\wbem
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
2) On executing dir command
Volume in drive C is OS
Volume Serial Number is 38D8-5C7C
Directory of C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx\WEB-INF\extensions
04/23/2017  04:18 PM    <DIR>          .
04/23/2017  04:18 PM    <DIR>          ..
03/22/2017  02:05 PM         8,837,096 FlxCore64.dll
03/22/2017  02:05 PM         7,400,560 libFlxCore.2016.08.dylib
03/22/2017  02:05 PM         4,315,316 libFlxCore.so.2016.08
03/22/2017  02:05 PM         4,650,664 libFlxCore64.so.2016.08
03/20/2017  11:18 PM               140 readme.txt
               5 File(s)     25,203,776 bytes
               2 Dir(s)  882,745,126,912 bytes free
It seems you are running Tomcat 8.5. Please downgrade to Tomcat 8.0.x - 8.0.33 (minimum).
I downgraded to tomcat 8.0.33 and still having the same issue.
I have a 32-bit processor machine and I am able to run 7.2 version of thingworx but whenever I am trying to deploy 7.4 version, getting below error
"Expecting Absolute path of Library Flxcore64.dll"
Note: I am simply copying thingworx.war in the web-apps folder of tomcat and already configured all the java related parameters in the tomcat.
32-bit processor is not supported. But you can try following:
Path of FlxCore64.dll is <Tomcat>\webapps\Thingworx\WEB-INF\extensions.
You can try to add the <Tomcat>\webapps\Thingworx\WEB-INF\extensions in PATH variable in the System environment variables.
When you downgraded Tomcat, is it still in the same location , C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5, or in some other location ?
How do you start Tomcat: as a service or as a program (executing the startup.bat script) ?
in any case, could you try the following:
-  open a NEW command prompt
- execute set PATH
- ensure that the path to <Tomcat>\webapps\Thingworx\WEB-INF\extensions is listed there (make sure the path to Tomcat is correct if it has changed due to downgrade - NOTE if you need to update the PATH variable do open a NEW command prompt after updating the PATH variable)
- move to <Tomcat>/bin
- execute startup.bat
if it still fails, could you post:
- startup.bat
- output of set PATH (again in case there is a change of directory after downgrade)
It is important to open a new command prompt after updating the PATH variable in Control Panel as an already opened commmand prompt will not see the update of environment variable.
Christophe,
I start tomcat using catalina.bat run as startup.bat window disappears after execution without allowing me to copy/troubleshoot the error message.
I updated the path to new variable as per the location of the new tomcat directory. However I am still getting the same issue. Below is the result of set path with new location of tomcat 8.0.33.
Path=C:\ProgramData\Oracle\Java\javapath;C:\Python27;c:\windows\system32;C:\HashiCorp\Vagrant\bin;C:\Program Files\Git\cmd;C:\Program Files\Git\usr\bin;C:\Program Files (x86)\PuTTY\;C:\Users\rishi\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files\nodejs\;C:\Program Files (x86)\Skype\Phone\;C:\Program Files\PostgreSQL\9.6\bin;C:\Windows\System32\wbem;C:\Users\rishi\Desktop\Rishit_Nevotek\IOT\apache-tomcat-8.0.33\webapps\Thingworx\WEB-INF\extensions;C:\Users\rishi\Anaconda3;C:\Users\rishi\Anaconda3\Scripts;C:\Users\rishi\Anaconda3\Library\bin;C:\Users\rishi\AppData\Local\Microsoft\WindowsApps;C:\Python27;C:\Python27\Scripts;C:\Program Files\Git\usr\bin;C:\Program Files\Heroku\bin;C:\Program Files (x86)\Microsoft VS Code\bin;C:\Users\rishi\AppData\Roaming\npm;C:\Users\rishi\AppData\Local\Google\Cloud SDK\google-cloud-sdk\bin;C:\Program Files\Docker Toolbox;C:\Program Files\PostgreSQL\9.6\bin;C:\Windows\System32\wbem;C:\Users\rishi\Desktop\Rishit_Nevotek\IOT\apache-tomcat-8.0.33\webapps\Thingworx\WEB-INF\extensions
Below is the output of catalina.bat run as startup.bat makes the window disappear after execution
Expecting an absolute path of the library: FlxCore.dll
2017-04-28 14:15:48.512-0500 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ====================================================================
2017-04-28 14:15:48.512-0500 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Failed to load FlxCore library. Ensure it's in PATH (Windows) or LD_LIBRARY_PATH(other platforms) or set with the VM arg, -Djava.library.path. Error message : com.flexnet.licensing.DllEntryPoint.entry([B)I
2017-04-28 14:15:48.512-0500 [L: WARN] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Shutting down the Platform
What are yoyr tomcat java settings?
Try this without the java path to the license file (in addition to the default settings):
-Dserver -Dd64
-XX:+UseNUMA
-XX:+UseConcMarkSweepGC
-Dfile.encoding=UTF-8
