Time Selector Widget - Calendar Start of week
nlindqvist
Is it possible to set Calendar (select date) to start weeks with Mondays instead of Sundays? Meaning the Sunday column below would shift to the far right.
1 ACCEPTED SOLUTION
Hi @nlindqvist ,
This is the design and cannot be changed.
Regards
bhawna
8 REPLIES 8
Hi @nlindqvist ,
Kindly check if the issue is similar to the raised ticket.
similar case
If not than, please share your version and other details.
Regards
Bhawna
nlindqvist
(To:bchaudhary)
The case looks to be for Windchill? This is for Thingworx, sorry if that was unclear. We are running version 9.2. I am trying to see if there is a way to get the weeks to start with Monday when opening the Calendar from a mashup using this widget:
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/TimeSelectorWidget.html#
/Kind Regards
Nils
Hey @nlindqvist ,
I hope you are using Date Time Picker widget and in the property field of the widget a field is available by the name of WeeklyCalendarStart.
Set the value of this field as Monday.
Attaching the screenshot for your reference.
nlindqvist
(To:bchaudhary)
Ok, no I am using the Time Selector Widget. I cannot find that setting there so assuming it is not possible then?
/Regards
Nils Lindqvist
Hi @nlindqvist ,
The Date Picker is the new one , may be that functionality is not present in earlier one .
If property is not present we can't change the sequence via composer.
Regards
Bhawna
nlindqvist
(To:bchaudhary)
"If property is not present we can't change the sequence via composer."
Does that mean that there is some other way to change it? Not using composer.
/Regards
Nils
Hi @nlindqvist ,
Regards
bhawna
nlindqvist
(To:bchaudhary)
Ok, thank you for the information.
