Hi community, hoping you are well, I am writing to ask you about the capabilities of Thingworx Analytics.
Hello @JZ_10390102 ,
This appears to be identical to a case entered with Technical Support and our Engineer has provided you with information for your use case.
I will share his response here for everyone on the PTC Community to see if they have similar questions.
Please refer to the following links:
ThingWorx Analytics Server, gather timeseries data to predict Time to Failure
Based on your feedback to the support engineer in your case, you have stated this provided a starting point/steps to begin your use case work.
With that indicated, would you be able to mark this thread as "solution accepted" if you have no further questions not answered in your case?
Neel
Neel
