Time series chart v2 - How cut values out of min and max range
fmanniti
Hello, in my Time series chart I have data which values go from -930 to 240 on Y axis.
I would like to change the Y scale range runtime by using two numeric widget.
The problem is, even if I change Min and Max values, higher or lower values will still be displayed.
Is there a way to cut the graph off?
PaiChung
22-Sapphire I
(To:fmanniti)
I didn't try this, but you did turn auto scaling off correct?
Yes I did. It works for the old widget but not for version 2
AdamR
(To:fmanniti)
Fabio,
This looks like it may be something that will require some more detailed investigation from PTC support.  I have created a new support case.  Someone from the support team will be in contact shortly to assist.
Thank you,
Adam
fmanniti
(To:AdamR)
Thank you very much
