TimeSeries chart Dual Y-axis labels
SaranKarthick
Hi Developers,
I'm working on a time series chart where i have to show two property graphs superimposed over each other so that the user would be able to see the influence of Property A (running hours in minutes) over Property B (No. of coils in counts). PFA the screenshot of the time series chart.
For this i have opted for dual y-axis option since the properties have different units. I'm not able to show the legends for the y-axis. I wanted to show "Counts" near the left side y-axis and "minutes" over the right one. And also the left y-axis is showing a range 0-220 and the left is showing 0-100. But it fells that the values of the property are more or less on the same scale which is not the case here. I want to show the significant change between the two property values in a way that the user would intuitively understand it.
Please suggest relevant options to configure for this.
Saran
For the legend, you can remove the legend from the graph, and add a left panel and a right panel with the corresponding yaxis legend with ValueDisplay widgets.
Hi @CarlesColl,
Thanks for this work around. Is there any other OOTB chart widget which could be more effective than the Time series for my use case?
Saran.
For what you said, I don't think so.
