Timeseries mashup
DMu3
Timeseries mashup
Hello sir,
Actually i am getting incoming json scripts in properties and alerts tab, In that json it contains timestamp,machinedatas, transcounter values, etc,. I need to show the transcounter value in mashup area. How to do that, can u please help me to do that?
cmorfin
(To:DMu3)
@DMu3
Could you please post a new topic with your question as this has nothing to do with the original question.
This is important so that we keep post clear and to one issue so others can find easily the answer.
In addition to your screenshot it probably will help to upload an export of the mashup and entities so one can see how the chart is being built.
Thank you
Kind regards
Christophe
7 REPLIES 7
PaiChung
22-Sapphire I
(To:DMu3)
Usually server side you'd use a script to parse out the information so it can be displayed in a Widget
Potentially the Expression function can parse it out for display
Or you could create a custom widget to do it.
Route 1 or 2 would be the easiest.
DMu3
(To:PaiChung)
Hii,
Server side is not possible. Can we create some service ? If its possible means how to create service in thing to see particular value of json?
rjanardan
(To:DMu3)
You could parse JSON to populate an Infotable
DMu3
(To:rjanardan)
In time series chart, my values are updating automatically, but i can't able to view the graph... I attached my screenshot below... please help me to do that.
cmorfin
(To:DMu3)
@DMu3
Thank you
Kind regards
Christophe
PaiChung
22-Sapphire I
(To:DMu3)
Information on your chart seem to imply that it doesn't recognize your x axis data as actual time stamp format.
you could try this in a label chart first to see the data before solving the formatting issue.
slangley
23-Emerald II
(To:PaiChung)
Hi @DMu3.
If the previous solution answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
If you have found a different solution, please post it here and mark that as the Accepted Solution.
--Sharon
