To Configure Dashboard
leokeinsfeld
Hello everyone,
I have a problem navigating between my menu options
When I run my dashboard runtime it works fine, but when I browse my menu, when I return to the dashboard some formatting ends up changing. Below images:
Can anyone help me with this?
leokeinsfeld
(To:slangley)
Hi @slangley
To resolve the issue I nedeed to change some property of label (for exampre: color or size) and after it to return to property that I wanted.
I do not know the why it happened but it was the only way that I found to resolve.
Thanks for your attention.
slangley
(To:leokeinsfeld)
Hi @leokeinsfeld.
Try testing it under different browsers to see if the same issue occurs.  If it's consistent across browsers, please provide your ThingWorx version (including patch level), so we can test it on our end.
--Sharon
slangley
(To:slangley)
Hi @leokeinsfeld.
Have you resolved your issue?  Did you try under different browsers to see if it was consistent?
Please let us know if you still need assistance.
--Sharon
leokeinsfeld
(To:slangley)
Hi @slangley
slangley
(To:leokeinsfeld)
Hi @leokeinsfeld.
Thank you for your follow-up post with the solution you found.  I will mark your post as the Accepted Solution for the benefit of others in the community.
Your participation in the community is greatly appreciated!
--Sharon
