I would like to upgrade Tomcat version without upgrading Thingworx version, currently my Tomcat version is 9.0.88 and it is showing as outdated by IT Department
Can we do anything my Thingworx version is 9.5.3
If I upgrade to Thingworx 10 I will get tomcat version 11
Here's how to do it: https://www.ptc.com/en/support/article/CS272588?
Release Advisor says supported version is 9.0.88 (here: https://release-advisor.ptc.com/releaseMatrix?releaseId=1865)
So you can update to the latest tomcat 9.0 release, currently 9.0.110.
If you want to go higher, you need to update ThingWorx to be on a supported platform.
Hi @VV_9240359,
It appears that this post may answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Abhi
Hello Abhi,
I will work on this solution by referring to the documentation, the solution provided by Rocko has all the information in detail. Yes I have marked it as Solution
TWXDev
