Transfer a file from two copies of Thingworx instances one local and one remote.
vkrishnamurthy
2-Explorer
I need to transfer file from my local server to remote service how can i achieve that?
You could use a mashup and use the file upload widget.
You could POST the file http/https
You could install a Thingworx Agent on the server you want to transfer from or on both servers and use the file transfer capabilities.
unfortunately I don't think it will work with Federation.
Can i use copy service? to transfer file between two instances?
How can i set virtual directory path from my thingworx service without edgeMicroServer?
You can use COPY to transfer a file between any two file repositories and that should apply to repositories defined at the device accessed by our Thingworx Agent or File Repositories defined on Thingworx platforms.
I've never tried it between two Thingworx instances, but if you use Federation it should? could? work?
On the platform it always needs a FileRepository which is a 'Thing' you define.
On a remote device you will need the Thingworx Agent, EMS or custom build with the SDK
Pai Chung
I'm trying to transfer an image from a smartphone to my TWX instance but have not succeded yet. I have tried to run the android-file-browser and havent succeded tho. Any sugestion here? I would appreciate it.
