Hi Team,
I am looking for file transfer approach from Thingworx Repository to different location.
Please let me know your inputs.
You can try with Java SDK, as explained here: https://community.ptc.com/t5/ThingWorx-Developers/Transfer-file-from-TW-Server-to-remote-JavaSDK/td-p/519042
Check also this article: https://www.ptc.com/en/support/article/CS297819
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
Hi @koushal.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
