Transformed properties don't work in Thingworx 8.5.
WangZhen
I just encountered this problem, when I tried to create some Transformed properties in Thingworx 8.5 and Platform Analytics 8.5, they didn't work. But all those kinds of properties worked fine in 8.4.
The transformed properties I created have a question mark, but not a thumb up sign.
And I also tried Statistics Calculation and Monitor services, they all worked normally.
Is it a bug or I missed any configuration?
Thanks in advanced.
1 ACCEPTED SOLUTION
cmorfin
(To:WangZhen)
Hi @WangZhen
I can confirm that Property Transform does work in release 8.5, so it is more likely to be an issue on your side.
I woudl recommend to go through the different log and configuration files to check for errors or mistake.
The article https://www.ptc.com/en/support/article?n=CS303523  lists all the item to check.
Hope this helps
Kind regards
christophe
cmorfin
(To:WangZhen)
Hi @WangZhen
Hope this helps
Kind regards
christophe
WangZhen
(To:cmorfin)
Hi Christophe,
Thanks for your kindly help.
I followed the instructions in those articles, it worked finally!
Best regards.
Wang Zhen
