The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I have a data grid with dynamic data (which are labels in string format).I need to translate those but don't have idea,how to do that.If I use localization method then it should be in a Mashup but as I said above its dynamically generated and Mashups have empty data grids.
You can use the Google Translate extension to create a service that translates these values or create a custom set of values in the localization tables and reference these in the service to manually do the substitutions.
Thanks Adam.
