I imported tree table widget successfully but after refreshing the thingworx composer it does not appear in the widget section please help to resolve the issue?
Maybe the steps from thsi post: https://community.ptc.com/t5/ThingWorx-Developers/Can-t-find-Paging-Extension-after-I-installed-it/td-p/658221 will help
Hi @yasmalik.
If the previous post allowed you to solve your issue, please mark it as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
