Tree Widget Style Definition
garambasic
I used different options for setting the style definition of my tree widget, but some of my elements are always displayed in default font.
(state dependant style, closed/open node)
In the attached image you can see that the first "newTestChild2" element is displayed with the TreeFormatter style, but the other two always appear in default style.
what am i doing wrong?
This could be a bug. Seems like you may want to open a support case for this
I do not see a problem based on the image. Are you sure these are not the same fonts? What version of ThingWorx are you using?
Hi Tori,
the image might be misleading, sorry.
I attached another one, where the difference is more clear.
I can't set the icon and the font for three elements of my tree.
All of the elements are supposed to be displayed with the same style, yet the latter 3 "newTestChild2" elements look different.
The ThingWorx version is 7.1.2-b6.
The Infotable result comes from a custom extension service.
