Here is the situation:
What I've checked so far:
Is this a defect/bug? Am I missing a step? Any and all help is appreciated!
Hi Eric,
This may not be ideal, but have you considered using the link widget instead?
Perhaps you can add a 'mashupURL' parameter to your contained mashup, and bind it to the link widget's LinkURL property. You can then hide this widget, and then bind the click event of your button to the Navigate service of the link widget. I have a feeling that this might be a good workaround.
Let me know if you are able to get it to work!
Andrew
Hi Eric,
Andrew
Thanks, Andrew - this is a good workaround. The link widget is working to do the same.
Would still love if the "TargetMashup" property worked on the Navigation function...
Glad to hear it's working! I've had the same issue as you in the past, so I'm hoping someone else knows why the TargetMashup property isn't working on the navigation function.
Andrew
Thanks Sharon!
Appreciate the update.
Andrew
when is the planned release date of 8.5.5 and was the Issue adressed?
For me it is very important for many projects.
I have only two possibilities ... wait for the update, if the bug was addressed or dont use thingworx for the projects.
Hi @bot1q.
ThingWorx 8.5.5 is targeted for release in late April. That date, however, is subject to change.
--Sharon
Hi @eribbeck.
If you feel your question has now been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
