Hello everyone,
I got a trouble with a file I want to import. I got this error message.
The most disturbing thing is that I made an export from 6.5 to 7.1.4, without no modification, so it should be that simple.
I tried to add the java options "-Dfile.encoding=UTF-8" and even to save the XML in different type of UTF-8, still doesn't work.
Have you a idea how I could solve it ?
Quentin
Well, I actually succeed in making it work.
I just change manually in the XML file the number of the version, minor version. And it worked, strange but it worked.
EDIT: actually, it is due to the xml export format. To avoid it, do an export to binary (.twx format).
Quentin
Hi Quentin Riviere, Just to confirm, was the tomcat restarted after making the changes?
Hello Gupta,
Yes, I confirm I restarted the tomcat, I even restarted the computer to be sure.
Quentin
Quentin
i am facing similar issue how i dont have XML back nly have binary format.. Can u please Suggest how to Change the format frm Binary to Xml or such Kind.
I don't know how to turn a Binary to a XML. It's only when exporting that you can select the format.
Actually, it's strange that you have a UTF8 trouble with the binary .twx file. Did you open it in a text editor (Notepad++) and saved it?
Best regards,
Quentin
