I'm working to import a lot of user between one Thingworx server to another Thingworx server, for that, I'm making a service for automatise the importation.
For that, I'm trying to use the "Thingworx/Importer" RestAPI Call.
The files are present in a FileRepository, but, when I search, in the RestAPI Call, for choose the FileRepository and import the requested XML File of a user, I don't see the option for...
Have you some ideas for import the user with the XML File ? (I have already done the exportation, and it work)
Thank you.
Hi @Mathis150 Look at the below article, and let us know your response.
https://www.ptc.com/en/support/article/CS292050?source=search
Hi @Mathis150,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
