Turn off Trace Logs
pshashipreetham
18-Opal
Turn off Trace Logs
I have an instance where the trace logs are generating heavily, resulting in data exceeding 50GB in just a couple of hours in PROD, and the C Drive becomes out of memory, causing the entire server to crash.
I need to disable only the trace logs in ThingWorx. I tried to find an article, but none have been found as of now.
How can we disable the Trace Logs in Thingowrx?
Thingworx Version: 9.0
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
How did you set it to TRACE?
You can try Monitoring>Application Log>Configure>LogLevel->Warn.
FYI Newer versions of ThingWorx auto-reset from Trace level after a defined period to avoid the situation you describe.
