Two ThingWorx installation in the same machine
fguerra
I'm looking for different extension in Thingworx but some extensions work on v6.5 and others on v6.6.
It is possible to deploy two ThingWorx version in the same machine?
I'm thinking on renaming the war files to something like thingworxv65.war and thingworxv65.war.
Regards
Felix
AdamR
(To:fguerra)
You would need multiple versions of Tomcat running, plus there would be potential JVM issues.  It is not recommended or supported to do this.  While in a strictly technically sense it may be possible (with the Postgres versions of Thingworx), you will likely run into issues.
AdamR
(To:fguerra)
fguerra
(To:AdamR)
Thank you Adam
If you have enough RAM and CPU you can run different virtual machines on the same machine at the same time
