Unable to Connect to MsSql External Database
SOLVED
Regular Member
Unable to connect ThingWorx 8.3.0-b349 to MS SQL external Database. I use the extension pointed by the various tutorials about, then I create a thing using the ThingTemplate MsSQL server. I've tried to change different parameters for the configuration tab. In the application log i receive the messages :
[message: Entity Not Found : [JdbcCreator]]
[message: Entity Not Found : [MySqlServer]] (note that I use the Template and parameters for Ms SQl not MySql)
[message: Unable To Convert From java.lang.String to NUMBER]
I verified that in the Tomcat folder lib there is the MsSql.jar file.
I used a similar procedure for Postgres Database and works, but I keep failing with MsSql.
1 ACCEPTED SOLUTION
Re: Unable to Connect to MsSql External Database
Hi @darcudarcu
I found these 2 articles which might be helpful, please check.
1.CS297147
2. CS295944
Vibhuti
7 REPLIES 7
Hi @darcudarcu
You may refer this community post External-database-connection-guide-for-ThingWorx-v8 for more information.
Also, please check these two articles.
  1. CS243088
  2. CS310222
Vibhuti
I can connect now.
However, in my DataBase I have two tables, I can query one table successfully but querying the other one gives me the error : Connection Closed.
Commands not related to a specific table (such as getdate()) work. The query is corrected because is tested  and copied and pasted from the database.
The two tables have the same connection properties.
@darcudarcu
Thanks for letting know that the connection issue is resolved.
Could you please provide the exact error/screenshot about the querying error?
@vangne
This is the error, note that querying another table of the same database it works fine.
Hi @darcudarcu
1.CS297147
2. CS295944
Vibhuti
Highlighted
Hi @vangne ,
the connection to the database works, the property "isConnected" is TRUE and the default line "GETDATE()" works. Also the query for "Table1" works, but I receive the error only with "Table2" belonging to the same database.
Hi @vangne ,
the problem was linked to a column data type not supported by thingworx ("sql_variant" for MS SQL).
To solve this problem I had to cast the value into a FLOAT.
Thanks for the support.
