Hi all,
I have a Mashup parameter that is an infotable, which consists a column as Checklsit which is another infotable. I want to export this Checklist infotable, but I am unable to. I am able to bind that infotable to a grid & it is available in the grid.
TWX 9.2
Thanks in advance,
Sujith
It is possible the DataExport widget only accepts a table from a service with a defined datashape, so if you really had to, ... it sounds a bit ... lame .. but you could create a dummy service that ingests and returns the infotable so it works with the DataExport widget.
