Unable to Invoke Service SendMessage on ACMEVendingNotifier
rtaylor-3
Going through the Thingworx training (Part 4). Predefined Thing Templates, creating a Notification thing.
When i test my Notification thing, i'm getting the following error.
Unable to Invoke Service SendMessage on ACMEVendingNotifier : 534-5.7.14 <https://accounts.google.com/ContinueSignIn?sarp=1&scc=1&plt=AKgnsbucv 534-5.7.14 M4s5oBHbUHlAJzlLVcMdtOaSt-1Xo_mIum6qnAcP_tMUmxdUOcg2D74hvj_-sbvBUvVnIy 534-5.7.14 AgsCpLF_DATE2UrZbp2J9OuvCtTkWt7o00HrBPsVWvNv00uMQsgn1972MIbbMH4H8DJ-uG 534-5.7.14 HGZpedoT-VZm0d14Qirj4UkIv0TLprvCv5-XTfk4YmEVsToCv_idrZmpnxUN4xI4h9D-J_ 534-5.7.14 PxZft1BKsh-yM1pBVzakndBGV0PY> Please log in via your web browser and 534-5.7.14 then try again. 534-5.7.14 Learn more at 534 5.7.14 https://support.google.com/mail/answer/78754 f7sm7034675qka.41 - gsmtp
I'm using SMTP.gmail.com on port 465. My TLS setting is unchecked and SSL is checked.
paic
(To:rtaylor-3)
Google has a security setting that blocks remote invokes like the one through Thingworx.
You can go into the google account and lower that setting.
That might be the cause here.
chichen
(To:rtaylor-3)
You can go to
http://www.google.com/settings/security/lesssecureapps
enable it and then test again.
thanks it works.
Hi, I'm having the same problem and I did what you said but I still get the message
Unable to Invoke Service SendMessage on ACMEVendingNotifier : null
Is there anything else you do?
Sorry, I restarted ThingWorx and it worked
