Hi all I'm using Thingworx 7.4 currently and I'm trying to Parse an Xml file below is my code
var params = {
proxyScheme: undefined /* STRING */,
headers: undefined /* JSON */,
ignoreSSLErrors: undefined /* BOOLEAN */,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: undefined /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
proxyHost: undefined /* STRING */,
url: "http://www.holidaywebservice.com/HolidayService_v2/HolidayService2.asmx/GetCountriesAvailable" /* STRING */,
timeout: undefined /* NUMBER */,
proxyPort: undefined /* INTEGER */,
password: undefined /* STRING */,
domain: undefined /* STRING */,
username: undefined /* STRING */
// result: XML
var result = Resources["ContentLoaderFunctions"].GetXML(params);
I'm getting this error.
Please help me fix it
Your TW Server has DNS resolution? As I've tested your code on my TW Server and it works smoothly.
Yes it has
Vemuri, the only time I get that error is if I give an invalid url, like holidaywebservices instead of holidaywebservice. Can you access that url link you're using in your service from the server that is hosting ThingWorx?
No I'm unable to access the url link that is being used in my service from the server that is hosting ThingWorx.
That might be the problem then. Is that website/ link blocked or blacklisted? Please try using a different link, maybe something like this one.
Even this link does not work in the server that we are using here.
Thingworx is running on a server, Please help.
Srilekha
Aanjan Ravi Below is the screen shot of the error that I'm getting while passing the url link that you suggested.
Please help, I'm not sure what is the error.
I tried getText, but the error is the same as stated above.
