Hello All,
I am trying to access my temperature sensor reading from my hosted ThingWorx server(which is in trial period). I am able to do so successfully using Postman.
Kindly also note that I am behind corporate proxy.
However, I am unable to access the sensor readings from a hosted angular 1 js web application(Azure VM). I repeatedly get CORS error.
I a not able to understand why this error doesn't arise from postman or my node-red flow.
Kindly suggest how can it be resolved.
Aarushi
Hello Aarushi,
I do apologize for the delay in getting back to you on this post.
Looking into this issue further the CORS error seems to be common in situations where ThingWorx was not explicitly configured to allow access.
Since this is a hosted ThingWorx environment you will need to open up a PTC Support ticket that requests our Cloud Team follow the procedures noted in the following article:
https://www.ptc.com/en/support/article?n=CS229450
You can open a support ticket by clicking here and proceeding to login. Please ensure that you reference the specific hosted instance you are working on as well as the domain you want CORS to be enabled for.
Tyler Misner
ThingWorx Technical Support Engineer
