I am also facing the same issue, Tomcat fails to start, and I see the same error message in the system event logs:
The Apache Tomcat 9.0 Tomcat9 service terminated with the following service-specific error: The system cannot open the file.
Could anyone who has resolved this issue provide some guidance or share their solution?
Thank you!
Hi @SD_10908519 ,
This is a permission issue. Check if Tomcat is running in Administrative mode. That's the root cause.
Hi @SD_10908519 Check the environment variable set for new java re-move the older path and check tomcat java option has connected to the new path.
Hi @Surya_Tiwari ,
1. I've confirmed that the Java environment variable is updated and correct.
2. Just to clarify, should I verify the JRE details from the Tomcat configuration? I’ve attached the relevant configuration file for your reference. Could you please provide more details on ensuring the Tomcat Java option is connected to the new path?
Thanks!
Hi @SD_10908519 Run the java version command in cmd and check the latest version shown and check at the Apache Tomcat Java Options:
Hi @SD_10908519,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Hi @SD_10908519 ,
