Unable to access Thingworx; error 503
Lo_ry96
Hello, I'm unable to connect to Thingworx web application. I'm having 503 error :
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Any ideas on what is causing this ? how to fix it ?
Many thanks
Hello @Lo_ry96
You can refer following article based on the 503 error you are getting
https://www.ptc.com/en/support/article/CS351588?source=search
https://www.ptc.com/en/support/article/CS394253?source=search
https://www.ptc.com/en/support/article/CS285508?source=search
If you still face the issue please share the application logs
VladimirN
(To:Lo_ry96)
Hello @Lo_ry96
Hello @Lo_ry96,
 It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
