Unable to bind mashup parameters of navigation function in ThingWorx 9.
ranjank
Unable to bind mashup parameters of navigation function. The bindings getting automatically removed after clicking on Done button of navigation function.
It is showing obsolete bindings were removed.
Thanks in advance.
slangley
(To:ranjank)
Hi @ranjank.
The fix for this issue was delivered in 9.1.  The fix will also be included in 9.0.4 which is scheduled for release in January.
--Sharon
7 REPLIES 7
cmorfin
(To:ranjank)
@ranjank
Could you upload some sample entities that reproduce your issue ?
I did a quick test but that worked fine on my side.
Christophe
ranjank
(To:cmorfin)
It is working when we bind directly any service output by dragging into navigation function parameter.
But it is not allowing to bind when binding via using 'configure bindings'.
cmorfin
(To:ranjank)
Hi @ranjank
I think it would help if you can provide a mashup and relevant entities and describe the step you take that do not work.
I have made a test in ThingWorx 9.0 and use the Configure Bindings of the Navigation Function and I have had no issue to perform the binding.
I guess there is something special with what you are doing hence it will be good to have an example.
Christophe
ranjank
(To:cmorfin)
It is not possible for me to share entities.
I am using responsive legacy layout.
cmorfin
(To:ranjank)
Hi @ranjank
Thank you, the added input about legacy layout was key.
I was indeed able to reproduce this behaviour in this situation.
As you already identified the drag and drop does work though.
I have reported this to R&D but being an issue with legacy widget I am not sure if a fix is possible.
You can though find details and reference at https://www.ptc.com/en/support/article/CS327316
Thank you
Christophe
slangley
(To:ranjank)
Hi @ranjank.
--Sharon
slangley
(To:slangley)
Hi @ranjank.
If you feel your issue has been resolved, please mark the appropriate response as the Accepted Solution for the benefit of others with the same problem.
--Sharon
