Unable to connect to an external Database using Thingworx
VV_9240359
Hello
With reference to this tip, I am not able to connect to external database
In properties section of DB Thing it is showing as not connected
But somehow some services are getting executed
Hey Rocko,
Thanks for the suggestion yes the "connectionValidationString" was correct the issue got resolved after restarting Tomcat and the "isConnected" property got checked.
Thanks.
First off, if the services are executed as you say, and deliver a result, I think we can consider the DB as connected.
Second, to make the "isConnected" work, you need to provide a proper test query when setting up the DB connection. Check "connectionValidationString" in the configuration tab.
Hey Rocko,
Thanks.
