Unable to connect to an external Database using Thingworx
VV_9240359
Hello
With reference to this tip, I am not able to connect to external database
In properties section of DB Thing it is showing as not connected
But somehow some services are getting executed
VV_9240359
(To:Rocko)
Hey Rocko,
Thanks for the suggestion yes the "connectionValidationString" was correct the issue got resolved after restarting Tomcat and the "isConnected" property got checked.
Thanks.
Rocko
(To:VV_9240359)
First off, if the services are executed as you say, and deliver a result, I think we can consider the DB as connected.
Second, to make the "isConnected" work, you need to provide a proper test query when setting up the DB connection. Check "connectionValidationString" in the configuration tab.
VV_9240359
(To:Rocko)
Hey Rocko,
Thanks.
