Hello ,
In thingworx 9.3.8 version i am unable to find the + icon of the datashape where we were able to create the datashape out of the result after execution of any query or script ,
If i try to create the new datashape then i will not get anything created in the fields definition .
Kindly help me out with this as soon as possible , if this issue is not solved then i can;t fetch any data to the mashup.
Below is the image where you can make out the difference what the problem is!
Shree
Hi @NH_shree,
Have you just upgraded your ThingWorx? I can see some raw information tokens at the place where the + icon is supposed to be.
You can try to clear the browser cache and re-do it again.
Hope it helps.
Hi @NH_shree,
Hope it helps.
