Unable to get ThingShapes to show Properties and Services on Import
amiller1
1-Newbie
Hello All,
Using Thingworx 6.5.0-b460 and thingworx-all-6.5.0-b460.jar as my library, I've been trying to create a ThingShape in code for import into Thingworx.  It gets imported, but the properties and services are not imported.  I was under the impression that I should be able to do this with 6.5.
Is this possible?  Does someone have a simple example?
Here is my test:
Code
package myPackage;
@ThingworxPropertyDefinitions(properties = {
   @ThingworxPropertyDefinition(name="MyProperty", description="", baseType="STRING", aspects={"isPersistent:true","isReadOnly:false"}),
   @ThingworxPropertyDefinition(name="MyOtherProperty", description="", baseType="NUMBER", aspects={"isPersistent:true","isReadOnly:false"}),
public class MyShape extends ThingShape {
   protected static Logger _logger = LogUtilities.getInstance().getApplicationLogger(HmiDisplayShape_geVisualization.class);
   @ThingworxServiceDefinition( name="MyService", description="" )
   @ThingworxServiceResult( name="result", description="", baseType="INFOTABLE", aspects={"dataShape:RootEntityList"} )
   public InfoTable MyService() throws Exception {
   return null;
Metadata
<ThingPackages>
   <ThingPackage name="myPackage"
   description=""
   className="myPackage.MyShape"
   aspect.isSystemObject="false" aspect.isCreatable="true" />
</ThingPackages>
<ThingShapes>
   <ThingShape name="MyShape" description="" thingPackage="myPackage" aspect.isSystemObject="false" />
</ThingShapes>
1 REPLY 1
qn
1-Newbie
1-Newbie
(To:amiller1)
Hi, what is the Extension SDK version are you using ?
