Unable to get the Data
kshirod.mishra
2-Explorer
Hi ,
I am unable to pull the column data from a table. I am getting an error as "Wrapped com.thingworx.common.exceptions.InvalidRequestException: Key field [SubProdName] had no value Cause: Key field [SubProdName] had no value". My objective is to pull one specific column data from one table and need to insert into Master Data Table. Please help me how to achieve this.
Thanks & Regards:
kshirod Mishra
There may not be enough information here, like when you look at the table, does the column have information in it?
What is the code you are using to retrieve the information?
Right now the error simply seems to say that the row of the field you are on has no value.
Thanks Pai. Now this issue has been resolved.....
Regards//
kshirod
