Unable to import extensions and files in ThingWorx 8.5 with postgres
svisveswaraiya
I upgraded to ThingWorx 8.5 recently. I have installed ThingWorx with Postgres 10. But when I try to import any extensions or files it shows error and doesn't import.Below is my platform setting json.
"PlatformSettingsConfig": {
"AdministratorUserSettings": {
"InitialPassword": "admin@123456789"
"ExtensionPackageImportPolicy": {
"importEnabled": true,
"allowJarResources": true ,
"allowJavascriptResources": true,
"allowCSSResources": true ,
"allowJSONResources": true ,
"allowWebAppResources": true,
"allowEntities": true,
"allowExtensibleEntities": true
"PersistenceProviderPackageConfigs": {
"PostgresPersistenceProviderPackage": {
"ConnectionInformation": {
"jdbcUrl": "jdbc:postgresql://localhost:5434/thingworx",
"password": "twadmin",
"username": "twadmin"
How can i resolve this?
Thanks in advance,
Shalini V.
3 REPLIES 3
What error is in Application.log?
Raluca Edu
Hi @raluca_edu ,
In logs, it always says Application key missing and websocket closed. I have attached my application log.
Hi @svisveswaraiya.
Your log file is too large to search unless you know what time the issue occurred.  If you're still having a problem, please stop Tomcat, move the logs to another location then restart.  Then provide the following information:
  • What extension are you trying to import?
  • Are you running ThingWorx Apps, Navigate, etc. and if so what version?  Note that ThingWorx products require very specific versions of ThingWorx
  • The log files located at \ThingworxStorage\logs
--Sharon
