Unable to install ThingWorx 9.4
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I've been trying to install Thingworx 9.4
Java - 11.0.21
Apache tomact - 10.1.15
Postgres 16.0-1
After deploying Thingworx.war in webapps, when I start the server, Thinworx is not starting. I get error message FAIL - Application at context path /Thingworx could not be started.
I've attached apache logs along with post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @Akj7579 ,
As per the release matrix which shared on above post. Can you please do the installation based on that? Beacuse Im not sure whether TWX 9.4 will run on Tomact 10.x. Kindly follow the attached matrix PDF.'s It will helps to find the exact issue in your environment.
- Apache Tomcat 9.0.75
- Oracle JDK 11.0.16
- PostgreSQL 13+ / PostgreSQL 14+/PostgreSQL 15.2+
- Thingworx 9.4.2 / Thingworx 9.4.1
Thanks & Regards,
Arun C
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @Akj7579 ,
Based on quick search found some couple links based on your Thingworx Manual Installation . Kindly have look on it. It ,may hepls you.
FAIL - Application at context path /Thingworx could not be started" is displayed
Please try to install everything at C: drive by creating all the ThingWorx folders at
- C:\ThingworxBackupStorage
- C:\ThingworxPlatform
- C:\ThingworxStorage
Also please find the below attached release matrix for TWX 9.4 for your confirmation.
Thanks & Regards,
Arun C
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @Akj7579 ,
I couldn't able to find the apache logs in your post. Can you please reshare it here?
Please check the Database server can able to access from Thingworx server incase of any firewall blockages and also check the Database with required Thingworx Tables are created by the admin credentials of Username & Password that were given in PlatformSettings.json file.
Another way to install TWX Foundation Installer 9.4 PostgreSQL by direct installation.
Thanks & Regards,
Arun C
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @Arun_C ,this is catalina log
24-Oct-2023 07:46:42.927 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/10.1.15
24-Oct-2023 07:46:42.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Oct 11 2023 23:38:40 UTC
24-Oct-2023 07:46:42.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 10.1.15.0
24-Oct-2023 07:46:42.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows Server 2022
24-Oct-2023 07:46:42.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
24-Oct-2023 07:46:42.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
24-Oct-2023 07:46:42.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jdk-21
24-Oct-2023 07:46:42.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 21.0.1+12-LTS-29
24-Oct-2023 07:46:42.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
24-Oct-2023 07:46:42.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 07:46:42.942 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 10.1\temp
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 10.1\conf\logging.properties
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: abort
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms128m
24-Oct-2023 07:46:42.984 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx256m
24-Oct-2023 07:46:43.361 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded Apache Tomcat Native library [2.0.6] using APR version [1.7.4].
24-Oct-2023 07:46:43.365 INFO [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized [OpenSSL 3.0.11 19 Sep 2023]
24-Oct-2023 07:46:43.645 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
24-Oct-2023 07:46:43.677 INFO [main] org.apache.catalina.startup.Catalina.load Server initialization in [922] milliseconds
24-Oct-2023 07:46:43.723 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
24-Oct-2023 07:46:43.723 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/10.1.15]
24-Oct-2023 07:46:43.739 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\docs]
24-Oct-2023 07:46:44.320 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\docs] has finished in [577] ms
24-Oct-2023 07:46:44.320 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\examples]
24-Oct-2023 07:46:45.397 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\examples] has finished in [1,077] ms
24-Oct-2023 07:46:45.398 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\host-manager]
24-Oct-2023 07:46:45.506 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\host-manager] has finished in [108] ms
24-Oct-2023 07:46:45.507 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\manager]
24-Oct-2023 07:46:45.561 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\manager] has finished in [54] ms
24-Oct-2023 07:46:45.561 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\ROOT]
24-Oct-2023 07:46:45.583 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\ROOT] has finished in [22] ms
24-Oct-2023 07:46:45.588 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
24-Oct-2023 07:46:45.634 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in [1950] milliseconds
24-Oct-2023 07:47:21.161 INFO [Thread-2] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8080"]
24-Oct-2023 07:47:21.177 INFO [Thread-2] org.apache.catalina.core.StandardService.stopInternal Stopping service [Catalina]
24-Oct-2023 07:47:21.189 INFO [Thread-2] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8080"]
24-Oct-2023 07:47:21.204 INFO [Thread-2] org.apache.coyote.AbstractProtocol.destroy Destroying ProtocolHandler ["http-nio-8080"]
24-Oct-2023 08:02:23.320 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/10.1.15
24-Oct-2023 08:02:23.329 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Oct 11 2023 23:38:40 UTC
24-Oct-2023 08:02:23.329 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 10.1.15.0
24-Oct-2023 08:02:23.331 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows Server 2022
24-Oct-2023 08:02:23.332 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
24-Oct-2023 08:02:23.332 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
24-Oct-2023 08:02:23.332 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jdk-21
24-Oct-2023 08:02:23.332 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 21.0.1+12-LTS-29
24-Oct-2023 08:02:23.332 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
24-Oct-2023 08:02:23.333 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 08:02:23.333 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 08:02:23.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 08:02:23.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 08:02:23.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 10.1\temp
24-Oct-2023 08:02:23.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
24-Oct-2023 08:02:23.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 10.1\conf\logging.properties
24-Oct-2023 08:02:23.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64
24-Oct-2023 08:02:23.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseG1GC
24-Oct-2023 08:02:23.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8
24-Oct-2023 08:02:23.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\Thingworx\WEB-INF\extensions
24-Oct-2023 08:02:23.340 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
24-Oct-2023 08:02:23.344 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
24-Oct-2023 08:02:23.344 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
24-Oct-2023 08:02:23.344 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
24-Oct-2023 08:02:23.344 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: abort
24-Oct-2023 08:02:23.344 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded Apache Tomcat Native library [2.0.6] using APR version [1.7.4].
24-Oct-2023 08:02:23.344 INFO [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized [OpenSSL 3.0.11 19 Sep 2023]
24-Oct-2023 08:02:23.644 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
24-Oct-2023 08:02:23.660 INFO [main] org.apache.catalina.startup.Catalina.load Server initialization in [513] milliseconds
24-Oct-2023 08:02:23.713 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
24-Oct-2023 08:02:23.713 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/10.1.15]
24-Oct-2023 08:02:23.755 INFO [main] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\Thingworx.war]
24-Oct-2023 08:02:43.895 INFO [main] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
24-Oct-2023 08:02:45.330 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal One or more Filters failed to start. Full details will be found in the appropriate container log file
24-Oct-2023 08:02:45.330 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
24-Oct-2023 08:02:45.343 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_CONSOLE] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
java.base/jdk.internal.misc.Unsafe.park(Native Method)
java.base/java.util.concurrent.locks.LockSupport.park(LockSupport.java:371)
java.base/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionNode.block(AbstractQueuedSynchronizer.java:519)
java.base/java.util.concurrent.ForkJoinPool.unmanagedBlock(ForkJoinPool.java:3780)
java.base/java.util.concurrent.ForkJoinPool.managedBlock(ForkJoinPool.java:3725)
java.base/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:1707)
java.base/java.util.concurrent.ArrayBlockingQueue.take(ArrayBlockingQueue.java:420)
ch.qos.logback.core.AsyncAppenderBase$Worker.run(AsyncAppenderBase.java:289)
24-Oct-2023 08:02:45.343 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_APPLICATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:02:45.343 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_CONFIGURATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:02:45.343 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_ERROR] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:02:45.344 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SCRIPT] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:02:45.344 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SCRIPT_ERROR] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:02:45.344 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SECURITY] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:02:45.344 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_AUTH] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:02:45.345 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_COMMUNICATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:02:45.345 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_DATABASE] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:02:45.345 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_AKKA] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:02:45.356 INFO [main] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\Thingworx.war] has finished in [21,599] ms
24-Oct-2023 08:02:45.356 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\docs]
24-Oct-2023 08:02:45.409 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\docs] has finished in [53] ms
24-Oct-2023 08:02:45.409 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\examples]
24-Oct-2023 08:02:45.653 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\examples] has finished in [243] ms
24-Oct-2023 08:02:45.653 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\host-manager]
24-Oct-2023 08:02:45.680 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\host-manager] has finished in [26] ms
24-Oct-2023 08:02:45.680 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\manager]
24-Oct-2023 08:02:45.705 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\manager] has finished in [25] ms
24-Oct-2023 08:02:45.705 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\ROOT]
24-Oct-2023 08:02:45.724 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\ROOT] has finished in [19] ms
24-Oct-2023 08:02:45.727 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
24-Oct-2023 08:02:45.743 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in [22076] milliseconds
24-Oct-2023 08:04:42.948 INFO [http-nio-8080-exec-4] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
24-Oct-2023 08:04:43.924 SEVERE [http-nio-8080-exec-4] org.apache.catalina.core.StandardContext.startInternal One or more Filters failed to start. Full details will be found in the appropriate container log file
24-Oct-2023 08:04:43.925 SEVERE [http-nio-8080-exec-4] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
24-Oct-2023 08:04:43.938 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_CONSOLE] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:43.938 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_APPLICATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:43.938 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_CONFIGURATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:43.938 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_ERROR] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:43.938 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SCRIPT] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:43.938 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SCRIPT_ERROR] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:43.939 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SECURITY] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:43.939 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_AUTH] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:43.939 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_COMMUNICATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:43.939 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_DATABASE] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:43.939 WARNING [http-nio-8080-exec-4] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_AKKA] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:04:52.401 INFO [Thread-24] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8080"]
24-Oct-2023 08:04:52.416 INFO [Thread-24] org.apache.catalina.core.StandardService.stopInternal Stopping service [Catalina]
24-Oct-2023 08:04:52.429 INFO [Thread-24] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8080"]
24-Oct-2023 08:04:52.445 INFO [Thread-24] org.apache.coyote.AbstractProtocol.destroy Destroying ProtocolHandler ["http-nio-8080"]
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/10.1.15
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Oct 11 2023 23:38:40 UTC
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 10.1.15.0
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows Server 2022
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jdk-21
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 21.0.1+12-LTS-29
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 08:05:43.588 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 10.1
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 10.1\temp
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 10.1\conf\logging.properties
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseG1GC
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\Thingworx\WEB-INF\extensions
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: abort
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded Apache Tomcat Native library [2.0.6] using APR version [1.7.4].
24-Oct-2023 08:05:43.604 INFO [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized [OpenSSL 3.0.11 19 Sep 2023]
24-Oct-2023 08:05:43.885 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
24-Oct-2023 08:05:43.917 INFO [main] org.apache.catalina.startup.Catalina.load Server initialization in [490] milliseconds
24-Oct-2023 08:05:43.963 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
24-Oct-2023 08:05:43.963 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/10.1.15]
24-Oct-2023 08:05:43.995 INFO [main] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\Thingworx.war]
24-Oct-2023 08:05:52.073 INFO [main] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
24-Oct-2023 08:05:53.439 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal One or more Filters failed to start. Full details will be found in the appropriate container log file
24-Oct-2023 08:05:53.439 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
24-Oct-2023 08:05:53.456 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_CONSOLE] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.456 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_APPLICATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.457 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_CONFIGURATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.457 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_ERROR] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.457 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SCRIPT] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.457 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SCRIPT_ERROR] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.457 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SECURITY] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.457 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_AUTH] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.458 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_COMMUNICATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.458 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_DATABASE] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.458 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_AKKA] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:05:53.468 INFO [main] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\Thingworx.war] has finished in [9,472] ms
24-Oct-2023 08:05:53.469 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\docs]
24-Oct-2023 08:05:53.509 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\docs] has finished in [39] ms
24-Oct-2023 08:05:53.509 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\examples]
24-Oct-2023 08:05:53.776 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\examples] has finished in [264] ms
24-Oct-2023 08:05:53.776 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\host-manager]
24-Oct-2023 08:05:53.806 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\host-manager] has finished in [30] ms
24-Oct-2023 08:05:53.806 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\manager]
24-Oct-2023 08:05:53.829 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\manager] has finished in [23] ms
24-Oct-2023 08:05:53.829 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\ROOT]
24-Oct-2023 08:05:53.851 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files\Apache Software Foundation\Tomcat 10.1\webapps\ROOT] has finished in [22] ms
24-Oct-2023 08:05:53.854 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
24-Oct-2023 08:05:53.873 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in [9953] milliseconds
24-Oct-2023 08:06:12.510 INFO [http-nio-8080-exec-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
24-Oct-2023 08:06:13.346 SEVERE [http-nio-8080-exec-1] org.apache.catalina.core.StandardContext.startInternal One or more Filters failed to start. Full details will be found in the appropriate container log file
24-Oct-2023 08:06:13.347 SEVERE [http-nio-8080-exec-1] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
24-Oct-2023 08:06:13.358 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_CONSOLE] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:06:13.358 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_APPLICATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:06:13.358 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_CONFIGURATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:06:13.358 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_ERROR] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:06:13.359 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SCRIPT] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:06:13.359 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SCRIPT_ERROR] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:06:13.359 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_SECURITY] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:06:13.359 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_AUTH] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:06:13.359 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_COMMUNICATION] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:06:13.360 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_DATABASE] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
24-Oct-2023 08:06:13.360 WARNING [http-nio-8080-exec-1] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [Thingworx] appears to have started a thread named [AsyncAppender-Worker-ASYNC_APPENDER_AKKA] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @Akj7579 ,
Thanks & Regards,
Arun C
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hello @Akj7579
Please refer following article based on error you are getting. If you still face the issue please share all the tomcat as well as twx logs.
https://www.ptc.com/en/support/article/CS329897?source=search
