I'm able to see the build gradle as text file when creating the Thingworx project not as a symbol to build the java file. Now what should I do to build the java code.
Hello, SaiSameera.
You are following steps similar to what is described in the below article, is the right? And the Java SDK Guide referenced therein?
https://www.ptc.com/en/support/article?n=CS226748
Let us know if that gets you started off in the right direction.
-- Craig A.
