Unable to show data on charts (Version 8.5 Trial)
SAnusha
7-Bedrock
I am trying to show infotable result on chart and mapped the respective service to chart.
When I am trying to specify the X-Axis properties,it's showing "No result found".
But the data is loading on grid. I have attached the respective screenshots.
Is it something like it's a bug or I am missing something.
Hi Raluca
It worked after tagging particular Datashape for the output. After doing that the fields are getting loaded.
6 REPLIES 6
Set first X-AxisField, and afterwards X-axisinterval.
Hope it helps,
Raluca Edu
Hi Raluca
Thank you for the response.
I am trying to set X-axis field. Drop down is related to X-axis field itself not interval.
Do you have any error in Application.log? Usually , you should see all fields in a drop-down list.
How many rows you have in the data you want to bind; do you have maybe specific types of data?
Raluca Edu
Hi Raluca
Thanks for sharing the solution.
Best regards,
Raluca Edu
slangley
(To:SAnusha)
Hi @SAnusha.
Have you been able to resolve your issue?  If so, please post the solution and mark it as the Accepted Solution for the benefit of others with the same problem.
--Sharon
