I am trying to show infotable result on chart and mapped the respective service to chart.
When I am trying to specify the X-Axis properties,it's showing "No result found".
But the data is loading on grid. I have attached the respective screenshots.
Is it something like it's a bug or I am missing something.
Hi Raluca
It worked after tagging particular Datashape for the output. After doing that the fields are getting loaded.
Hi Raluca
Thank you for the response.
I am trying to set X-axis field. Drop down is related to X-axis field itself not interval.
Do you have any error in Application.log? Usually , you should see all fields in a drop-down list.
How many rows you have in the data you want to bind; do you have maybe specific types of data?
Raluca Edu
Hi Raluca
Hi @SAnusha.
Have you been able to resolve your issue? If so, please post the solution and mark it as the Accepted Solution for the benefit of others with the same problem.
Regards.
--Sharon
