Unable to start EMS using wsems
apdams
6-Contributor
I have a Thingworx foundation server and am trying to get the EMS started on the same machine, but am having some trouble. These are the steps I have followed:
1. I installed MED-61060-CD-053_SP5_Microserver-5-3-4-2383-Win32
2. I configured the config.json file with this (the app key is from my ThingWorx application key
 "ws_servers": [{
   "host": "localhost",
   "port": 8080
 "appKey": "c03fa7e6-ab2f-47bd-9b0b-3d93e2bd03c9"
3. When I try to start ems using wsems, I get this output:
[INFO ] 2020-04-17 03:44:43,187 wsems: Using config file: C:\ems\microserver\etc\config.json
[FORCE] 2020-04-17 03:44:43,187 wsems: Starting up ....
[FORCE] 2020-04-17 03:44:43,187 wsems: Initializing EMS ....
[FORCE] 2020-04-17 03:44:43,187 main: Using config file C:\ems\microserver\etc\config.json
[FORCE] 2020-04-17 03:44:43,192 httpServer: starting http server port=8000
localhost:8080-->[ERROR] 2020-04-17 03:44:43,202 httpserver: Server socket error
: Couldn't bind address [*:8000]
[ERROR] 2020-04-17 03:44:44,242 SDK: Error intializing socket connection.  Err = -1
[ERROR] 2020-04-17 03:44:44,242 SDK: twWs_Connect: Error restarting socket.  Error 0
What do I do to fix this?
Adrian
cmorfin
(To:apdams)
Hi @apdams
your config.json does not show anything on port 8000, shouldn't you check the url  http://192.168.1.33:8084/Thingworx/Things/LocalEms/Properties/isConnected  instead ?
Christophe
7 REPLIES 7
apdams
6-Contributor
(To:apdams)
I think I am making progress, but still not all the way there.
I changed my config.json to look like this:
  "ws_servers": [{
    "host": "192.168.1.33",
    "port": 80
  "appKey": "c03fa7e6-ab2f-47bd-9b0b-3d93e2bd03c9",
  "logger": {
 "publish_directory": "logs",
    "level": "DEBUG",
    "publish_level": "INFO",
 "max_file_storage": 2000000,
 "auto_flush": true,
 "flush_chunk_size": 16384,
 "buffer_size": 4096
  "ws_connection": {
    "encryption": "none",
    "verbose": true
  "http_server" : {
  "port": 8084,
  "ssl": false,
  "content_read_timeout": 20000,
    "authenticate": false
  "file": {
 "virtual_dirs": [
  {"logs": "logs"},
  {"instruction":"instruction"}
 "staging_dir": "c:\\ems\\microserver\\staging"
From the output when I run wsems, I think it is getting further. This is the output:
192.168.1.33:80-->[INFO ] 2020-04-17 04:30:08,55 wsems: Using config file: C:\em
[FORCE] 2020-04-17 04:30:08,55 wsems: Starting up ....
[FORCE] 2020-04-17 04:30:08,55 wsems: Initializing EMS ....
[FORCE] 2020-04-17 04:30:08,55 main: Using config file C:\ems\microserver\etc\co
nfig.json
[INFO ] 2020-04-17 04:30:08,55 wsems: Creating the WsEms proxy.
[INFO ] 2020-04-17 04:30:08,55 wsems: Starting HTTP Server.
[INFO ] 2020-04-17 04:30:08,55 wsems: Initializing the ThingWorx REST interface.
[DEBUG] 2020-04-17 04:30:08,55 SDK: twWs_Create: Initializing Websocket Client f
or 192.168.1.33:80//Thingworx/WS
[DEBUG] 2020-04-17 04:30:08,55 SDK: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2020-04-17 04:30:08,60 SDK: twApi_Initialize: Websocket Established afte
r 0 tries
[DEBUG] 2020-04-17 04:30:08,60 SDK: subscribedPropsMgr_Initialize: Initializing
subscribed properties manager
[DEBUG] 2020-04-17 04:30:08,60 jsonConfigurator::getJsonEntity: Parent certifica
tes not found
tes not found
[DEBUG] 2020-04-17 04:30:08,60 SDK: twTunnelManager_Create: Tunnel Manager singl
eton already exists
[DEBUG] 2020-04-17 04:30:08,60 jsonConfigurator::getJsonEntity: Key auto_bind no
t found
[INFO ] 2020-04-17 04:30:08,60 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2020-04-17 04:30:08,60 wsems: Starting the connection.
[FORCE] 2020-04-17 04:30:08,65 httpServer: starting http server port=8084
[DEBUG] 2020-04-17 04:30:08,65 httpServer: http server bound to port=8084.
[DEBUG] 2020-04-17 04:30:08,85 SDK: twTlsClient_Reconnect: Re-establishing SSL c
ontext
[DEBUG] 2020-04-17 04:30:08,85 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2020-04-17 04:30:08,85 SDK: twWs_Connect: Error initializing web socket.
  Response code: 404
So, question is: how do you solve the Response code: 404 error?
Adrian
slangley
(To:apdams)
Hi @apdams.
Please check this article to see if it helps.  If you still have issues, please let us know.
--Sharon
apdams
6-Contributor
(To:slangley)
Hi Sharon
I have (I think) made more progress.
This is my latest config file (changed the ws_servers port to 8080):
  "ws_servers": [{
    "port": 8080
  "logger": {
    "level": "DEBUG",
 "auto_flush": true,
 "buffer_size": 4096
  "ws_connection": {
    "verbose": true
  "http_server" : {
  "port": 8084,
  "ssl": false,
  "certificates":{
 "validate":false,
 "allow_self_signed":true
  "file": {
 "virtual_dirs": [
  {"logs": "logs"},
Now, when I run wsems on the command prompt, it sort of looks like it is working. This is what I get:
192.168.1.33:8080-->[INFO ] 2020-04-17 05:28:45,236 wsems: Using config file: C:\ems\microserver\etc\config.json
[FORCE] 2020-04-17 05:28:45,236 wsems: Starting up ....
[FORCE] 2020-04-17 05:28:45,236 wsems: Initializing EMS ....
[FORCE] 2020-04-17 05:28:45,236 main: Using config file C:\ems\microserver\etc\config.json
[INFO ] 2020-04-17 05:28:45,236 wsems: Creating the WsEms proxy.
[INFO ] 2020-04-17 05:28:45,236 wsems: Starting HTTP Server.
[INFO ] 2020-04-17 05:28:45,236 wsems: Initializing the ThingWorx REST interface.
[INFO ] 2020-04-17 05:28:45,241 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2020-04-17 05:28:45,246 wsems: Starting the connection.
[FORCE] 2020-04-17 05:28:45,246 httpServer: starting http server port=8084
[INFO ] 2020-04-17 05:28:45,271 SDK: twWs_Connect: Websocket connected!
[INFO ] 2020-04-17 05:28:45,306 Main: Succesfully connected.  Saving .booted config file
The documentation, however, says that if it starts successfully, "You can tell that WS EMSisrunningand connectedto ThingWorx platformby lookingat the consoleprompt— two plus signs(++) indicatethat it is runningand connected"
I don't see any + signs. Does that mean it is not actually started/connected?
I get this response. Looks like it is not connected!! What am I missing?
rows
0
isConnected false
datashape
fieldDefinitions
isConnected
name "isConnected"
description ""
baseType "BOOLEAN"
aspects {}
cmorfin
(To:apdams)
Hi @apdams
Christophe
apdams
6-Contributor
(To:cmorfin)
i Christophe
That was it.
Thanks a lot
Adrian
apdams
6-Contributor
(To:cmorfin)
Hi Christophe
Something very strange has happened. Earlier, my EMS was working and I could query the connected status and it was returning true. I am running the same config file, but now I am getting this in the output and the connected status is false:
192.168.1.33:8080-->[INFO ] 2020-04-17 10:21:21,302 wsems: Using config file: C:
[FORCE] 2020-04-17 10:21:21,302 wsems: Starting up ....
[FORCE] 2020-04-17 10:21:21,302 wsems: Initializing EMS ....
[FORCE] 2020-04-17 10:21:21,302 main: Using config file C:\ems\microserver\etc\config.json
[INFO ] 2020-04-17 10:21:21,302 wsems: Creating the WsEms proxy.
[INFO ] 2020-04-17 10:21:21,302 wsems: Starting HTTP Server.
[INFO ] 2020-04-17 10:21:21,302 wsems: Initializing the ThingWorx REST interface.
[INFO ] 2020-04-17 10:21:21,317 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2020-04-17 10:21:21,317 wsems: Starting the connection.
[FORCE] 2020-04-17 10:21:21,317 httpServer: starting http server port=8084
[INFO ] 2020-04-17 10:21:21,357 SDK: twWs_Connect: Websocket connected!
[WARN ] 2020-04-17 10:21:21,362 SDK: api:sendMessageBlocking: AUTH Message 1 failed.  Code:
[WARN ] 2020-04-17 10:21:26,367 SDK: twWs_Connect: Already connected
[WARN ] 2020-04-17 10:21:26,367 SDK: twWs_Receive: Websocket closed!
[WARN ] 2020-04-17 10:21:26,367 SDK: msgHandlerOnClose: WEBSOCKET CLOSED
[WARN ] 2020-04-17 10:21:26,372 SDK: api:sendMessageBlocking: Receive failed.
[WARN ] 2020-04-17 10:21:26,372 SDK: api:sendMessageBlocking: Message 2 timed ou
t
What is happening here?
Adrian
apdams
6-Contributor
(To:apdams)
Turns out to be the application key had expired.
Suggestion: the error message "api:sendMessageBlocking: Receive failed." is not particularly useful. Something like "application key has expired" would be more useful
