Hi All,
We will host a live Expert Session: "Thignworx Active Active Clustering" on January 21th 8h00 EST.
Please find below the description of the expert session and the registration link.
Expert Session: Thignworx Active Active Clustering
Date and Time: January 21th 8h00 EST
Duration: 1 hour
Host: Ayush Tiwari - IoT Product Manager
Registration Here: https://www.ptc.com/en/customer-success/expert-sessions-for-thingworx-foundation-webcasts (scroll down, the session is in the bottom of the page)
Description:
This session will cover the main aspects of the High Availability Clustering feature for High Availability configuration launched with the ThingWorx 9.0 release. Join us and bring your questions with you!
Existing Recorded sessions can be found on support portal using the keyword ‘Expert Sessions’.
You can also suggest topics for upcoming sessions using this small form.
Here are some recorded sessions that might be of your interest. You can find recordings for the full library of webinars using the keyword ‘Expert Sessions’ in PTC support portal search
Upgrade to Thingworx 9 – How to Plan / Evaluate Impacts This session highlights the key points you should evaluate to properly plan your upgrade to Thingworx 9 |
Thingworx Flow Overview Flow is a powerful component of the ThingWorx platform. This session will take the Flow discussion beyond basic applications and into more customized and complex solutions. This will focus on use cases, main features such as triggers, connector options, main enhancements for Thingworx 9.0 and a short demonstration |
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
