Upcoming Live Expert Session - Thingworx Flow Overview
dsantos
We will host a live Expert Session: "Thingworx Flow Overview" on December 10th, 8h00 EST.
Please find below the description of the expert session and the registration link.
Expert Session: Thingworx Flow Overview
Date and Time: December 10th, 8h00 EST
Duration: 1 hour
Host: Antony Moffa; Vinay Vaidya - Thingworx IoT Platfom Senior Directors
Registration Here: https://www.ptc.com/en/customer-success/expert-sessions-for-thingworx-foundation-webcasts
Description:
Overview of Thingworx Flow, an application for integration and orchestration between systems. This will focus on use cases, main features such as triggers, connector options, main enhancements for Thingworx 9.0 and a short demonstration.
Existing Recorded sessions can be found on support portal using the keyword ‘Expert Sessions’.
You can also suggest topics for upcoming sessions using this small form.
Here are some recorded and upcoming sessions that might be of your interest. You can also find recordings for the full library of webinars using the keyword ‘Expert Sessions’ in PTC support portal search
Top 5 items to check for Thingworx Performance Troubleshooting
How to troubleshoot performance issues in a Thingworx Environment? Here we cover the top 5 investigation steps that will help you understand the source of your environment issues and allow better communication with PTC Technical Support
Recording Link
Upgrade to Thingworx 9 – How to Plan / Evaluate Impacts
This session will highlight the key points you should evaluate to properly plan your upgrade to Thingworx 9
Register Here
Active Active Clustering
This session will cover the main aspects of the High Availability Clustering feature launched with the ThingWorx 9.0 release
Register Here
0 REPLIES 0
