UploadThing
ketanaga
UploadThing
Hi
I am trying to setup an analytics server for my TWX platform, for which I am stuck on getting the UploadThing zip file to be installed on the server. Attached you will find the extracted Thingworx_Analytics_Extension files in which UploadThing.zip should also be present however it is missing.
Workaround needed
ketanaga
(To:anarwal)
Thanks for the clarification and the video tutorial
cmorfin
(To:ketanaga)
Hi @ketanaga
Thank you for your post.
The UploadThing was a mechanism used in older version (I think until 8.1). It is no longer needed.
All you need is the extension file you have in the screenshot you posted.
You do have to be careful and make sure you follow the compatibility matrix though (https://support.ptc.com/help/thingworx_hc/thingworx_analytics_8/#page/analytics%2Fcompatibility%2Fthingworxanalytics_compatibility_8_5_later.html%23
By the way, where did you find that uploadthing was needed ? I'd like to see if the document can be updated if we have something that still mention it.
Christophe
anarwal
(To:cmorfin)
Hi @ketanaga , Yes it is not required after 8.1 you must be following old documentation.
Link to how to install thingoworx analytics video.
https://www.ptc.com/en/support/article/CS314203
ketanaga
(To:anarwal)
ketanaga
(To:cmorfin)
@cmorfin
Thanks for the clarification. I followed this documentation
cmorfin
(To:ketanaga)
Hi @ketanaga
Thank you for the link.
How did you get to that link ?
Do you have a document that pointed you to it ?
This is the Help Center for ThingWorx Analytics 7.4, though this page exist, it is no longer referenced in the Help Center page: https://www.ptc.com/en/support/help/Thingworx .
You should definitely not use that link .
Thank you
Christophe
