Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
I would like to use the PredictorThing to perform scoring with the RealtimeScore service in order to be able to use this service via the REST API.
I want to provide the data input temporally without the need to save a (small) dataset every time. But I don't know excatly how do I have to pass the datasetRef InfoTable correctly, when I want to pass the input parameters as json/in body. In the nested InfoTable of the metadata field, I pass the fieldnames, optype, dataType etc, and in the value fieldname, I pass the data corresponding to the field, beginning with the oldest value. Back in the datasetRef Infotable, I pass "json" as format and "body:/" at dataSetUri.
I get the following error message:
Could not process request: [Unable to process JSON [refer to logs for more details]]
This is the json body of the request:
{ "modelUri": "results:/models/d081b9f3-fcd2-4f94-b839-07f8961b6d63", "datasetRef": { "created": 1521639099629, "description": "", "name": "Infotable", "dataShape": { "fieldDefinitions": { "filter": { "name": "filter", "aspects": {}, "description": "SQL WHERE clause to refine the dataset", "baseType": "STRING", "ordinal": 3 }, "datasetUri": { "name": "datasetUri", "aspects": {}, "description": "Location of the data", "baseType": "STRING", "ordinal": 1 }, "metadata": { "name": "metadata", "aspects": { "dataShape": "AnalyticsDatasetMetadata" }, "description": "Metadata of the dataset (for providing data as part of request)", "baseType": "INFOTABLE", "ordinal": 6 }, "data": { "name": "data", "aspects": {}, "description": "An infotable of data (must be flat. for providing data as part of request)", "baseType": "INFOTABLE", "ordinal": 5 }, "format": { "name": "format", "aspects": {}, "description": "Structure of the data (CSV,PARQUET,CLQUET)", "baseType": "STRING", "ordinal": 2 }, "exclusions": { "name": "exclusions", "aspects": { "dataShape": "GenericStringList" }, "description": "Fields to remove from the dataset", "baseType": "INFOTABLE", "ordinal": 4 } }, "name": "AnalyticsDatasetRef", "description": "Reference to a dataset" }, "rows": [{ "datasetUri": "body:/", "metadata": { "created": 1521639557758, "description": "", "name": "Infotable", "dataShape": { "fieldDefinitions": { "timeSamplingInterval": { "name": "timeSamplingInterval", "aspects": {}, "description": "Time between observations in a Temporal field", "baseType": "INTEGER", "ordinal": 7 }, "isStatic": { "name": "isStatic", "aspects": { "defaultValue": false }, "description": "If true, this field remains unchanged over time", "baseType": "BOOLEAN", "ordinal": 8 }, "fieldName": { "name": "fieldName", "aspects": {}, "description": "Name of the field", "baseType": "STRING", "ordinal": 1 }, "min": { "name": "min", "aspects": {}, "description": "Minimum observed value for Continuous fields", "baseType": "NUMBER", "ordinal": 4 }, "max": { "name": "max", "aspects": {}, "description": "Maximum observed value for Continuous fields", "baseType": "NUMBER", "ordinal": 5 }, "dataType": { "name": "dataType", "aspects": {}, "description": "Format of the data (STRING,DOUBLE,BOOLEAN,INTEGER)", "baseType": "STRING", "ordinal": 2 }, "opType": { "name": "opType", "aspects": {}, "description": "Behavior of the data (CONTINUOUS,CATEGORICAL,ORDINAL,BOOLEAN,TEMPORAL,ENTITY_ID)", "baseType": "STRING", "ordinal": 3 }, "values": { "name": "values", "aspects": { "dataShape": "GenericStringList" }, "description": "Collection of possible values for Ordinal and Categorical fields", "baseType": "INFOTABLE", "ordinal": 6 } }, "name": "AnalyticsDatasetMetadata", "description": "Metadata describing the fields of a dataset" }, "rows": [{ "isStatic": false, "fieldName": "asset_id", "dataType": "STRING", "opType": "ENTITY_ID", "values": { "created": 1521639563486, "description": "", "name": "Infotable", "dataShape": { "fieldDefinitions": { "item": { "name": "item", "aspects": { "isPrimaryKey": true }, "description": "Item", "baseType": "STRING", "ordinal": 0 } }, "name": "GenericStringList", "description": "Generic data shape to hold a list of strings" }, "rows": [{ "item": "test" }, { "item": "test" }, { "item": "test" }, { "item": "test" }, { "item": "test" }, { "item": "test" }, { "item": "test" }, { "item": "test" } ] } }, { "isStatic": false, "fieldName": "A", "dataType": "DOUBLE", "opType": "CONTINUOUS", "values": { "created": 1521639564074, "description": "", "name": "Infotable", "dataShape": { "fieldDefinitions": { "item": { "name": "item", "aspects": { "isPrimaryKey": true }, "description": "Item", "baseType": "STRING", "ordinal": 0 } }, "name": "GenericStringList", "description": "Generic data shape to hold a list of strings" }, "rows": [{ "item": "1" }, { "item": "3" }, { "item": "5" }, { "item": "7" }, { "item": "9" }, { "item": "11" }, { "item": "13" }, { "item": "15" } ] } }, { "isStatic": false, "fieldName": "B", "dataType": "DOUBLE", "opType": "CONTINUOUS", "values": { "created": 1521639564675, "description": "", "name": "Infotable", "dataShape": { "fieldDefinitions": { "item": { "name": "item", "aspects": { "isPrimaryKey": true }, "description": "Item", "baseType": "STRING", "ordinal": 0 } }, "name": "GenericStringList", "description": "Generic data shape to hold a list of strings" }, "rows": [{ "item": "1" }, { "item": "3" }, { "item": "5" }, { "item": "7" }, { "item": "9" }, { "item": "11" }, { "item": "13" }, { "item": "15" } ] } }, { "isStatic": false, "fieldName": "C", "dataType": "DOUBLE", "opType": "CONTINUOUS", "values": { "created": 1521639566311, "description": "", "name": "Infotable", "dataShape": { "fieldDefinitions": { "item": { "name": "item", "aspects": { "isPrimaryKey": true }, "description": "Item", "baseType": "STRING", "ordinal": 0 } }, "name": "GenericStringList", "description": "Generic data shape to hold a list of strings" }, "rows": [{ "item": "1" }, { "item": "2" }, { "item": "3" }, { "item": "4" }, { "item": "5" }, { "item": "6" }, { "item": "7" }, { "item": "8" } ] } }, { "timeSamplingInterval": 1, "isStatic": false, "fieldName": "time", "dataType": "DOUBLE", "opType": "TEMPORAL", "values": { "created": 1521640129762, "description": "", "name": "Infotable", "dataShape": { "fieldDefinitions": { "item": { "name": "item", "aspects": { "isPrimaryKey": true }, "description": "Item", "baseType": "STRING", "ordinal": 0 } }, "name": "GenericStringList", "description": "Generic data shape to hold a list of strings" }, "rows": [{ "item": "1" }, { "item": "2" }, { "item": "3" }, { "item": "4" }, { "item": "5" }, { "item": "6" }, { "item": "7" }, { "item": "8" } ] } }, { "isStatic": false, "fieldName": "failure", "dataType": "BOOLEAN", "opType": "BOOLEAN", "values": { "created": 1521641692805, "description": "", "name": "Infotable", "dataShape": { "fieldDefinitions": { "item": { "name": "item", "aspects": { "isPrimaryKey": true }, "description": "Item", "baseType": "STRING", "ordinal": 0 } }, "name": "GenericStringList", "description": "Generic data shape to hold a list of strings" }, "rows": [{ "item": "0" }, { "item": "0" }, { "item": "0" }, { "item": "0" }, { "item": "0" }, { "item": "0" }, { "item": "0" }, { "item": "0" } ] } } ] }, "format": "json", "exclusions": { "created": 1521639557815, "description": "", "name": "Infotable", "dataShape": { "fieldDefinitions": { "item": { "name": "item", "aspects": { "isPrimaryKey": true }, "description": "Item", "baseType": "STRING", "ordinal": 0 } }, "name": "GenericStringList", "description": "Generic data shape to hold a list of strings" }, "rows": [] } } ] }, "goalField": "ttf", "preferredCategoricalValues": { "created": 1521639099684, "description": "", "name": "Infotable", "dataShape": { "fieldDefinitions": { "item": { "name": "item", "aspects": { "isPrimaryKey": true }, "description": "Item", "baseType": "STRING", "ordinal": 0 } }, "name": "GenericStringList", "description": "Generic data shape to hold a list of strings" }, "rows": [] } }
Hi
Apologies for late answer.
I have written an article that covers how to score data from the body of a REST call. It is available at https://www.ptc.com/en/support/article?n=CS282398 .
It does contains a sample dataset and scoring json request which is probably the most useful part of the article.
I believe you can use this to amend your rest call.
Note when scoring time series , you do need to pass an amount of data that is at least equal to the Lookback window of your model (see https://support.ptc.com/help/thingworx_hc/thingworx_analytics_8/#page/thingworx_analytics_8%2Ftwxa-time-series.html).
These values need to be passed in the data field not the metadata one.
hope this helps
Christophe
Hi
Just to let you know I am checking on this ... no answer as yet but I will post as soon as I have something useful.
Thank you
Kind regards
Christophe
Hi
hope this helps
Christophe
