hello,
I have Thingworx platform in my work place that uses Kepserver layer to collect data from machines , store it in MSSQL DB and then use Thingworx web application to visualize data.
I have the idea of using Grafana as visualization tool instead thingworx mash ups (more convenient to business) . What is the architecture suited to this need? I'm thinking about using API calls to populate an influxDB and then querry this DB in Grafana.
Any ideas on this ?
Hi @Lo_ry96,
I have done this before for another use case. Below are the steps:
Take a look:
Hi thanks for shared info. Any ressources/ides on how to perform GET requests to fetch data from Thingworx? i'm turning around since a while as i'm starter to Thingworx platform so any guidance is appreciated
Many thanks
Some tips:
Hello @Lo_ry96,
It looks like you have a response from a community member. If any of these replies helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
Hi @Lo_ry96,
