Use Thingworx API to store data in InfluxDB
Lo_ry96
hello,
I have Thingworx platform in my work place that uses Kepserver layer to collect data from machines , store it in MSSQL DB and then use Thingworx web application to visualize data.
I have the idea of using Grafana as visualization tool instead thingworx mash ups (more convenient to business) . What is the architecture suited to this need? I'm thinking about using API calls to populate an influxDB and then querry this DB in Grafana.
Any ideas on this ?
Hi @Lo_ry96,
I have done this before for another use case. Below are the steps:
  1. Add Influx as the Secondary Persistence Provider in Thingworx
  2. Create a value stream, while the creation of a Value stream selects the Secondary Persistence Provider instead of "ThingworxPersistenceProvider":
  3. Then assign the value stream you have created to a Thing
  4. Create the Properties and check the log while creating the Property
  5. Once the Log is checked, when data comes to the property it gets stored in the Influx DB
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
VladimirN
(To:Lo_ry96)
Take a look:
Hi thanks for shared info. Any ressources/ides on how to perform GET requests to fetch data from Thingworx? i'm turning around since a while as i'm starter to Thingworx platform so any guidance is appreciated
Many thanks
VladimirN
(To:Lo_ry96)
Hello @Lo_ry96
It looks like you have a response from a community member. If any of these replies helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
Hi @Lo_ry96,
Shashi Preetham,
