I am trying to connect an OPC UA Server to a KepServer using certificates at both machine and user level.
In the machine certificates part, I have already managed to communicate both devices, using an example user.
When I try to configure the communication without a user and communicate via certificates, I can't find where I have to configure the certificate.
Best regards,
At this time, authentication via certificate is not supported. Authentication through the Kepware User Manager is the only option.
Best regards,
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
Best regards,
Andy Servetas
