Is there a quick way to create a user group that has access to run everything but not have editing rights (composer rights) or do I have to create a group and then add it to everything that is run on the mashup?
Thank you,
Hi Michael a great way to do this is to first create groups that have the proper permissions (remember you can add groups to groups and their permissions will stack)
Then create additional groups if needed which form your User groups.
add those groups to the permission groups.
Add users to the User groups.
Of course you can skip the middle step if that isn't required.
In follow up to that. It is best to specifically permit the runtime and not mass permit the runtime, many of the runtime services can impact the design and should be kept secured.
