I am trying to reset password for a user in Form Login. There it asks to fill userID.
where can I find the user ID of a user?
I feel that userID is the name of the user. Can you try that?
Raluca Edu
Hi Shruti,
Did you try User Extensions and Groups?
yes I checked in user extensions. There is no UserID
Can you brief the flow to get landed onto this Reset Password screen. Are you trying to change password while logged-in or trying to change password without logging-in?
Raluca Edu
yes userid and username are same. Got it. Thank u
Hi @Sruthi.
Please mark the appropriate response as the Accepted Solution. This will help others on the community with the same question.
Regards.
--Sharon
I have marked the solution said by raluca as Accepted.Please check
