Using OUTPUT in SQL Command
jensc
I wanted to use the "OUTPUT" clause in an SQL command to get the latest inserted row.
However I am getting this error:
Execute Update failed: com.microsoft.sqlserver.jdbc.SQLServerException: A result set was generated for update.
Now, the SQL that i am using does work in SSMS. Here is the structure:
INSERT INTO Table
(value1, value2)
OUTPUT Inserted.uid
values(1,2)
Any ideas?
I would if possible like to avoid using stored procedures.
Use service type as "Query" as following,
dgg
(To:jensc)
Try using a table variable to capture the identity column value for the newly inserted row:
declare @uid int;
declare @tableOut table(uid int);
insert into SOMETABLE (
FIRST_NAME,
LAST_NAME output
INSERTED.UID into @tableOut values (
'Neil',
'Peart'
); select @uid = uid from @tableOut;
hope that helps,
dgg
I was under the assumption that insert/update/delete only worked using the "command" type of SQL on TWX.
This is exactly what I was looking for!
Jens
jensc
(To:dgg)
While it gives me what I wanted, it is a bit more convoluted then I would have hoped.
Satish Kumars response works as well and is perhaps easier to understand.
Jens
