Using getXML() with HTTPS site using self-signed certificate
billtra
Hi. I'm trying to create a service which calls getXML() to access a remote API over HTTPS, which is enabled using a self-signed certificate. When I test it, I only get a PKIX error that it cannot validate the certificate. I have tried setting the ignoreSSLErrors flag, but it still errors out. Here is the service's script:
var params = {
ignoreSSLErrors: 1 /* BOOLEAN /,</div></div><div><div>    url: "https://server:81?API=GET_SERVER_LIST&XML=1" / STRING */
// Load page
var xmlPage = Resources["ContentLoaderFunctions"].GetXML(params);
Bill Tranmer
7 REPLIES 7
smanley
(To:billtra)
Hi Bill,
Is there a reason you are using 1 in place of true for the boolean value? I suggest specifying true of false for Boolean values.
Saeed
billtra
(To:smanley)
Hi Saeed,
Thanks for your comment. I was testing various things just to try to affect a change in the response. Setting to "true" also does not work.
Bill
smanley
(To:billtra)
Hi Bill,
I'd like to get a little more information. If you enter the url directly into a browser, are you able to see the content after confirming the prompt to accept the certificate?
Saeed
Hi all,
I've got the same issue.
The ignoreSSLErrors = true does not work.
Still have the error :
Wrapped javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target Cause: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Does someone know how i can fix it ?
Just to be sure, does the ignoreSSLErrors parameter (set to True) avoid the installation of the certificate on my jdk ?
hi all,
          this same issue i am facing can anyone help me out in this "SSLHandshakeException"error.
chichen
(To:billtra)
